Hi.
Following an MOT test I have had intermittent BAS/ESP light showing and very occasional ABS light too. I changed the brake light switch, no difference. Also tried the lock to lock trick many times, also no difference. I then had the codes read (of course the lights all stayed firmly off when I took the car in). Codes recorded were a few for offside rear sensor and one for steering angle. I suspect something in the MOT test triggered it so either jacking the car and loosening a wire or turning steering rapidly.
So, first step was to check the connections to offside rear wheel sensor. Now, here is my question: If this sensor had failed, would I not get ABS light as well as ESP/BAS? I tried unplugging it and the ABS light comes on too as I would expect. I don't want to change the sensor if this rules it out. I suspect more the steering wheel sensor for the main problem of the BAS/ESP and the code recorded for rear sensor being just for the brief period when the ABS light came on too.
Any info appreciated. Thanks
Dave
Registered 2000 SLK320
I've had a similar issue with the BAS/ESP light. Ended up taking it to my local MB dealer to have the codes read. £25 well spent as it identified exactly which sensor needed replacing.
Thanks Guys
I have had the codes read as in the original post. Thing is as I have two faults, the offside rear sensor and the steering angle. Hence my question: 'Would not the rear sensor also throw up an ABS warning if faulty? That narrows down my problem as the ABS light only showed briefly, the BAS/ESP is on all the time. I'm not going to throw more money at getting codes read again. Unplugging the rear sensor puts the ABS light on too. It's a simple sensor with just two wire connection so I'm 90% sure that it either works or it doesn't . Can't see how it could work for ABS but not BAS/ESP. Just need some expert verification of that and I can get on with replacing the steering sensor.
The 4 wheel sensors have input to ABS and BAS/ESP as well as cruise ctrl. They are all to do with wheel speed.
I had a bad sensor on the N/S/F. In the end I also replaced the yaw sensor, though the latter had stopped giving me trouble.
