1 - 12 of 12 Posts
Fault code -311 is showing on the instrument cluster when started. The engine idles very nicely but when the throttle is applied engine bogs down and nearly dies. I have the maf out for cleaning and I inspected the k40, it appears to be ok. Don't want to pull the trigger on a new k40 until I know what the -311 code means.
Erlingiii,
Want to post a picture? Start a new thread or make a post, click ‘edit’, click on the ‘paper clip’ or ‘advanced’ and/or ‘manage attachments’ then ‘choose file’ then ‘upload’ and ‘submit’!
Post your vin in the Vehicle Datacard Request section to get a datacard (options on your car). http://www.slkworld.com/vehicle-data-card/
Minion
P0311 Cylinder #11 Misfire Detected
google search result*
Possible causes
- Faulty spark plug 11
- Clogged or faulty fuel injector 11
- Faulty ignition coil 11
- Fuel injector 11 harness is open or shorted
- Fuel injector 11 circuit poor electrical connection
- Ignition coil 11 harness is open or shorted
- Ignition coil 11 circuit poor electrical connection
- Insufficient cylinder 11 compression
- Incorrect fuel pressure
- Intake air leak
Help with this
Tech notes
The P0311 code means that the cylinder 11 is misfiring or is randomly misfiring. Start by checking for intake leaks an if no leaks are found the next step is to replace the spark plugs on cylinder 11. If the problem persist more tests needs to be done to diagnose problem, see "Possible Causes"
Help with this
When is the code detected?
Engine Cylinder 11 is Misfiring.
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Lack/loss of power
- Hard start
- Engine hesitation
P0311 Mercedes-Benz Description
When a misfire occurs, engine speed will fluctuate. If the engine speed fluctuates enough to cause the Crankshaft Position (CKP) sensor signal to vary, the Engine Control Module (ECM) can determine that a misfire is occurring.
Read more: http://engine-codes.com/p0311_mercedes-benz.html#ixzz2fqfK7ZdC
Thanks for the info, I also found another misfire thread and it was due to bad gas, this is a possibility cause the car has been sitting for 2 years. I'll put new fuel in tomorrow and then go from there. If the fuel is bad I imagine I would be getting multiple misfires. Thanks for your help
Premium Member 1998 SLK230
Ok I feel a little silly but I'm learning. I cleared the dash, scanned the obd2,here are the code: 300, 303,304, 100, 110.
I have cleaned the maf (probably needs replacement)
New spark plugs
New air filter
Before I spend 200 on a maf I was wondering if there could be any other culprit
Could it be a vacuum hose, Pcv, or oil separator?
I'm no mechanic, but I can turn a wrench, so with the help of you kind folk, I might be able to get this thing running.
Check your crank-case hoses for any leaks or splits. The codes 0300-303 and 304 are those current or stored?
It is possible that your MAF has gone bad, however I am surprised that it is just a 0100 without a 0170, 0171, 0172 code to go with it. That is usually what happens when the MAF goes bad, the fuel bank can't keep the fuel balance in check and the car runs too lean or too rich. Could just be a short in the wire and thus still working often enough to throw a bank fault code.
What did you clean the MAF with? MAF cleaner, Carburetor cleaner, something else?
Are you aware that you can test a MAF with a voltmeter or a multimeter?
How many times have you driven the car since you pulled the codes? How many miles have you driven since the plugs have been changed and the MAF has been cleaned?
Mine took almost 100 miles before the engine light went off. Unfortunately, it came back on and the MAF had gone bad. Also, I have read that the car must be "driven" for at least 3 drive cycles before the engine light will clear itself. To jump start the process, crank your car. Let it run for 1 minute 30 seconds. Turn off car for 5 minutes and crank and run again. 3rd time, actually drive it.
If you will give us some more details we can help you sort it out or at least feel more confident that it is a bad MAF. Did you post how many miles are on the car? If not, that info is good for us to have as well.
"Could just be a short in the wire and thus still working often enough to throw a bank fault code."
That is NOT to throw a bank fault code:D
P0300 Random misfire detected A. Random misfire B. Random misfire, TWC damaging
P0303 Cylinder 3 misfire detected Cyilnder 3 misfire, TWC damaging
P0304 Cylinder 4 misfire detected Cylinder 4 misfire, TWC damaging
P0100 MAF Circuit Malfunction Hot film MAF sensor
P0110 IAT circuit malfunction IAT sensor (in hot film MAF sensor)
It could be a bad or contaminated maf & or bad coil.
1 - 12 of 12 Posts
