1 - 20 of 21 Posts
I need to replace the LED indicator in the passenger side mirror as they barely work. They flicker at times but barely light at all. The mirror casing/mirror/indicator outer plastic arrow are not broken.
Is the replacement LED lens unit the same as that in the pre facelift 171 shown in the video link elsewhere on this site/You tube.
Anyone have the part number ? Thanks
Post your vin. get your free datacard and your part number :D
If you check eBay , the ones on offer are 2005-2008 which would suggest that pre-facelift and facelift , aren't the same !
I'm in epc now and the part number for left and right side are different so waiting for your vin to get you the driver's or pass or both numbers
Thanks curro101, that's what I was thinking. Didn't want to order one just in case.
datacard posted
right a1718100464 9197 9197 is obsidian black
left a1718100364 9197
blinker part of mirror assembly in pre facelift
your car was delivered in mar 2008. so is your car facelift or not? it would have had to be made at least 2 months earlier. facelift in europe was 2008/9 and later. my facelift was delivered in May 2008
the part numbers are from your vin in your request thread and the blinker is not available by itself per epc for your vin. blinker part of lamp assembly per your vin.
The door mirror is the same as that in the 2009 SLK brochure - arrow shaped which I think is post face lift. Here is a picture. SAM_4505.jpg
definitely facelift
hope that helped you. :D
Discussion Starter #15
Now I've posted a picture, hopefully someone will know if you can get a separate LED blinker unit for this door mirror (and where).:smile:
DAS/STAR Registered Owner
Ebay may be your best bet ...
I have a F/L cover back at home, but not sure which side ... (bought for a test fit)
I'll check later..
The one I have is the drivers side ....nuts!!
1 - 20 of 21 Posts
