Need to scan your car, you can do that with a chep obd2 or a very expensive DAS tool.
don't know if this is any good for youThanks for the quick reply... I will have a look to see the scanner ... Any recommends? Thanks Mart...
Don't do that, i have my wife C class kompresor staling a few weeks ago and ignore the cell and now the car is not starting at all, i believe the timing chain jump a tooth so I am gutted.If it doesn't go out by itself you could try a battery reset: remove the negative from the battery for 30 mins then reconnect (without hesitation/sparks) , you'll need to reset the clock and the auto windows afterwards..
At this point i am a bit paranoia with MB cars, check your car just to see is nothing wrong with the balance shaft sprocket , stalling the car can put some strain on the chain and balance shaft. Again you are in that range with your car.Only had the car a few weeks it is a 2005 280 Manual... Getting used to the clutch on a new car I have stalled it a few times ...But yesterday after a stall and restarting, the engine check light came on .... Car runs perfectly. Will the light extinguish after a few drives? Or any advice will be very welcome.... Thanks in advance... Marty.
My fears were confirmed today, timing gears are caput... Some tooth missing and the chain jumped... Very expensive job.Hope it's nothing too serious !
