Can someone measure the resistance of their connected passenger seat airbag? I have a code for it and want to see what the resistance should be.
Thank You!
Sadly Woolly has passed away
You can't effectively measure it when it's connected, as you'll be meausuring everything upstream of it as well. It should be roughly the same as the drivers side when disconnected.
That is a good point. I guess the first step would be to measure the resistance of the airbag unplugged. Do you have a number for what that should be?
as woolly said:
measure the drivers one.
reason for this is, you will be using the same multimeter so this will rule out variances in two different meters. :tu:
