New member here. I installed new brake pads & rotors on my 2013 SLK250. Afterward, one of the parking brakes would not operate, and in the center display was a RED Parking Brake - See Owners Manual message. For the one brake which was working, it worked as usual. So, I replaced the electric drive/motor on the other brake, still the same issue. I could apply a 12 volt power source to the electric motors one at a time, get them to turn one direction, then reversing polarity, they turn the other direction. When on the caliper, they would clamp the rotor and release the rotor. But that one side would not function from the normal means. I took it to the dealer, and they suggested replacing the one caliper. Not sure what that would do since the motor works, the caliper works, they just don't work from the switch in the car.
So, I put 2 voltmeters on the real brake connector and actuated the parking brake switch. Neither volt meter indicated voltage, not positive or negative (since I don't know which way the meter would have been connected). After this test, neither parking brake will operate with the normal in car button. I located all 3 fuses associated with the parking brake circuit, and tested them - of course they are fine.
Without a wiring diagram, I am at a loss. Anyone have any suggestions? I am likely to have to tap out and take the car to the dealer. Has anyone experienced this same issue and what was the fix?
2005 SLK55 AMG
Hi John, and welcome to SLKWorld.com from the UK Midlands - Thanks for joining us! :)
I can't help with your question, but hopefully other members will be along shortly with some useful advice for you...
In the meantime, please update your location and vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300, 320, 350, 55) in your profile if you haven’t already done so, as it helps the members answer your questions which usually are based on that information.
Follow this to update: ‘User CP’ at the top of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘location’ and ‘vehicle’ (and then click ‘SAVE CHANGES’ button at the bottom of the page). Info in your garage does not update your profile.
Also, your 1st thread should be your introduction so we can welcome you properly, so please post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already:
  • Post your VIN (or VIN of a car you're looking at) in the Vehicle Datacard Request section to get a free datacard (options on the car).
    FREE!! How to get a free data card!
  • If you haven’t, please use the 'search' feature at the top right of the page for your questions as they have probably been asked before. Remember, ‘Search’ is your friend.
  • If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM.
  • Want to post a picture? Start a new thread or make a post, click ‘edit’, click on the ‘paper clip’ or ‘advanced’ and/or ‘manage attachments’ then ‘choose file’ then ‘upload’ and ‘submit’! If iPhone pics, you need to rename any additional pics as iPhone names its pics all the same, image.jpg.
  • Want to 'like' or 'thank' someone’s comments? Use the ‘like’ button to the right or the ‘Thanks’ button, bottom right of any individual’s post that you like. This saves you having to comment.
  • New members should be aware that the 'New Posts' link in the info bar towards the top of the screen is a great way to see all of the posts you have missed since you were on the forum last. Remember to click 'mark forums read' under ‘quick links’ when you leave.
  • Also vote or enter our Ride of the Month competition: ROTM Submissions & Voting - Mercedes Benz SLK Forum
Dave
**Registered 2009 SLK200
Did you not tell the car you have fitted new rear brakes on car so it will callibrate the electonic side of the handbrake ?
As in put it on a diagnostic machine ??
Im 99% certain they need to be reset calibrated like most modern elec handbrake .
2012 SLK350
