1 - 17 of 17 Posts
Registered 2004 SLK200 KOMPRESSOR
Is there a way of dumping complete car config with DAS/Star? I want to do some off-line checks to diagnose why rain sensor doesn't work.
Registered 2005 SLK350-sold
I was going to post this on a new thread, but if you have an Android device, and a OBD2 Bluetooth adapter (they are under $20) there is a program called "Carly". It will do a complete dump of every item in the car and what it reports. The free version is limited, but you do a dump, and email it to them, and they reply back with it decoded. Or you can flip through the screens and read it all yourself. It is amazing the amount of info. Also with their own adapter, you can actually PUSH info from your phone onto the MFD in the car, weather, txt messages, appointments...
I may purchase it.
Here is what they provided, there is a lot of temporary faults that could be 10 years old, I will clear and retest soon.
Base: Series 171 - SLK Roadster/ Baureihe 171 - SLK RoadsterBuild-Year: 2005Faults: 30ECUs: 29Filter: just foundModel: all/alle (MotorID=ME97, Parameter=23)Battery: 13.3VEnhanced communicationNormal connectionOptimized: 100NoneDate: 2016-05-04 06:57:34OBDIIVersion: 21Device: >samsung< >hltevzw< >SM-N900V<Motor Control: ME - Motor/Engine Electronics (MB: 0014468340) ECU OK, no Fault or Event CodeABS / DSC / Brake: WSS - Weight sensing system (MB: NO_HWID_FOUND) ECU not present/no response from ECUAirbag: AB - Airbag (MB: 1718203626) Fault: Fault in communication with component B48 (Front passenger seat occupied and child seat recognition) or there is a cable fault. If fault code occurs with no complaint reported and no malfunctions, erase fault memory and perform a function check. Fault in communication with component B48 (Front passenger seat occupied and child seat recognition) or there is a cable fault. If fault only occurs after rapid ignition status change, ignore fault. / Fault: N2/7 (Restraint systems control unit): coding is faulty. Code: 009022Transmission Control: ETC - Electronic transmission control (MB: 0335456732) ECU OK, no Fault or Event Code ESM - Electronic selector module (MB: 1715450232) ECU OK, no Fault or Event CodeInstrument cluster: OCP - Overhead control panel (MB: 1718201301) Fault: The supply voltage of the control unit is too low (undervoltage). The voltage was less than 9.0 V during 3 s. / Event: The supply voltage of the control unit is too low (undervoltage). / Fault: Control unit N70 (Overhead control panel control unit) is defective. Code: 009001 IC - Instrument cluster (MB: 1715402111) Event: The supply voltage of the control unit is too low (undervoltage). / Fault: The brake fluid level is not o.k. Code: 009128 UCP - Upper control panel (MB: 1718208210) Fault: Switch Outside mirror adjustment is defective or has been operated for longer than 25 seconds. / Fault: Switch N72/1s30 (STH switch) is defective or has been operated for longer than 120 seconds. This fault code can be ignored if component N33 (Stationary heater control module) is not installed. / Fault: Switch N72/1s12 (Rear door wiper switch) is defective or has been operated for longer than 25 seconds. Not Relevant! Code: 009012Light/Rain Control: HRA - Headlamp range adjustment (MB: 2118200985) ECU OK, no Fault or Event CodeHeating / AC: C-AAC - Convenience automatic air conditioning / AAC - Automatic air conditioning / HEAT - Automatic heater (MB: 1718300185) Fault: Electrical fault B31 (C-AAC multifunction sensor) Not Relevant! / Fault: B31 (C-AAC multifunction sensor) / Fault: B31 (C-AAC multifunction sensor) B31 (C-AAC multifunction sensor) Important note: If no customer complaint exists, the fault can be erased. B31/2 (Air humidity sensor) B31/2 (Air humidity sensor) Important note: If no customer complaint exists, the fault can be erased. Code: 009450Immobilizer System: ASSYST Active Service System (MB: 2115403545) ECU OK, no Fault or Event Code ASSYST PLUS - PLUS Active Service System (MB: 2115403545) Fault: Coding of control module ASSYST PLUS is faulty. / Fault: Coding of control module ASSYST PLUS is faulty. Note: If the service menu is properly displayed in the instrument cluster, this fault can be ignored. Code: 009102Park distance control: PTS - Parktronic system (MB: NO_HWID_FOUND) ECU not present/no response from ECUSunroof / Roof: VR - Vario roof (MB: 1718203326) ECU OK, no Fault or Event CodeAudio/Navi/Communication: TEL / NAVI (MB: 2118700289) Sorry, there is no explanation available Code: 00D010 Sorry, there is no explanation available Code: 00D200 Sorry, there is no explanation available Code: 00D241 Sorry, there is no explanation available Code: 00D242 COMAND or AUDIO (MB: NO_HWID_FOUND) ECU not present/no response from ECU NAVI or SDAR - Satellite radio (MB: NO_HWID_FOUND) ECU not present/no response from ECU COMMAND / Audio / Handy Interface (MB: 2118706790) ECU OK, no Fault or Event Code TEL / CD Changer (MB: 2208703589) Sorry, there is no explanation available Code: 00D010 Fault: Watchdog error : The control unit has been reset due to an internal error. Code: 00D001 UCI - Media Interface (MB: NO_HWID_FOUND) ECU not present/no response from ECU AGW - Audio gateway (MOST network management, diagnosis gateway, radio tuner) (MB: 2118272062) Fault: The supply voltage of the control unit is too low (undervoltage). Not Relevant! Code: 00D010Systems: ESP - Electronic stability program (MB: 0345456032) ECU OK, no Fault or Event Code EZS - Electronic ignition switch (MB: 2115451408) ECU OK, no Fault or Event Code SCM [MRM] - Steering column module (MB: 1715450332) ECU OK, no Fault or Event Code REAR SAM - Rear signal acquisition and actuation module (MB: 1715450101) Fault: Circuit 30 has an undervoltage of < 10.5 V. This fault is mainly listed when the engine is started. Low voltage only occurs when the fault is erased after engine is started and then appears again. Code: 009039 Fault: Control module N72/1 (Upper control panel control unit) is not sending any data. / Fault: Control unit N72/1 (Upper control panel control unit) is not transmitting data on the CAN bus. / Fault: Fault in CAN communication with control unit N72/1 (Upper control panel control unit). If fault code occurs with no complaint reported and no malfunctions, erase fault memory and perform a function check. / Fault: Error: relay terminal 15R1, load side circuit to GND Code: 009096 SAM-F - Signal acquisition and actuation module front (MB: 1715450001) Fault: Low beam left short circuit or no load / Fault: Component E6/1 (Left front side marker lamp USA) or lead has Short circuit to ground or open circuit. / Fault: Component E1e2 (Left low beam) is faulty or the line to the component has a short circuit or open circuit. / Fault: Error: Side marker defective right Code: 009010 Fault: Voltage of the terminal 30 at 10.5V / Fault: Component M6/1 (wiper motor) has Overload. / Fault: Circuit 30 has an undervoltage of < 10,5 V. / Fault: Event: SG DBE will not transmit CAN-B (timeout) failure message DBE Code: 009051 Fault: Air compressor short circuit or no load / Fault: Component E1e1 (Left high beam) or the lead has short circuit. Component E2e1 (Right high beam) or the lead has short circuit. / Fault: Component A9 (AC compressor) or the line to the component has a short circuit to ground or open circuit. Code: 009000 System diagnosis (MB: 2115403545) ECU OK, no Fault or Event Code GPS box (MB: 2214460059) Fault: Component ''Backup antenna ''TELEAID'''' has an open circuit. Component 'Backup antenna 'TELEAID'' has an open circuit. Code: 00D632 Fault: CAN bus OFF fault Code: 00D641 Fault: A timeout occurred during authorization. Code: 00D6B5 CGW - Central gateway (MB: 2115403545) ECU OK, no Fault or Event CodeBody: HS - Seat heater (MB: 1718201626) ECU OK, no Fault or Event Code ESA passenger - Electric seat adjustment front passenger (with memory) (MB: 2118700726) Fault: Fault in CAN communication with control unit EZS. / Fault: CAN-Statusinformation EZS (Time-out) Code: 009852 Fault: Fault in CAN communication with control unit REAR SAM. / Fault: CAN-Statusinformation SAM_H (Time-out) Code: 009853 Fault: Fault in CAN communication with control unit ICM. / Fault: CAN-Statusinformation Kombi (Time-out) Code: 009854 ESA driver - Electric seat adjustment driver (with memory) (MB: 2118700526) Fault: Fault in CAN communication with control unit EZS. / Fault: CAN-Statusinformation EZS (Time-out) Code: 009852 Fault: Fault in CAN communication with control unit REAR SAM. / Fault: CAN-Statusinformation SAM_H (Time-out) Code: 009853 Fault: Fault in CAN communication with control unit ICM. / Fault: CAN-Statusinformation Kombi (Time-out) Code: 009854 Fault: Plug 7 is not inserted or a line has a short circuit to positive. Not Relevant! Code: 009307 DCM-L - Door control module left (MB: 1718200726) ECU OK, no Fault or Event Code DCM-R - Door control module right (MB: 1718200626) Fault: Component M21/2r1 (Mirror heater) has Open circuit. / Fault: There is a discontinuity in the line to component M21/2r1 (Mirror heater) or the component is defective. Code: 009211 Fault: S20/1s2 (Right power windows switch) : The component remains in the switched status (contact sticking) or has Short circuit. S21/2 (Front passenger power window switch) : The component remains in the switched status (contact sticking) or has Short circuit. / Fault: Component S20/1s2 (Right front power window switch) hanging. Erase and ignore fault code: the component is not installed in this model series and (or) vehicle variant. ( Steering version ) / Fault: S20/1s2 (Right front power window switch) : The component is hung or has a short circuit. Not Relevant! / Fault: S20/1s2 (Right front power window switch) : Component does not operate or has short circuit. Code: 009502
Looks very useful. Which Bluetooth adapter did you use? Was it a specific make or just a generic one?
Some generic one I got cheap. I got it for use with "Torque" which is really cool. I like playing with the H.U.D. mode and seeing my speed reflected on the windshield. The "Push Notifications" part of Carly look really cool. I think you need the expensive Gen 2 adapter that they sell for it and purchase a license for Carly, maybe $80 total, I might bite on that, looks too cool not to.
Deutsch -
English -
Registered 2006 SLK55 AMG
License. Well worth it. I use a generic Code reader - not the one they sell.
I do find the interface a bit slow or buggy, but it does everything I want in a code reader including resetting. In fairness my android tablet isn't the fastest, and I'm not using their reader ... so I don't truly know where the "peculiarities" I've encountered are coming from.
Bottom line: the pluses far outweigh the negatives.
tn
Thanks for this. On a Facelift '170 I am not going to need or be able to use push, so I'll just get a ELM 327 compatible one and see what the free apps can give me.
Cheers.
Savcom
Thanks! I have to say it looks very impressive and much more detailed than I expected. But I need more - i..e I need to see if rain sensor has been enabled in OCP. Faults/events are not enough.
I'll try can dig through the screens and do a capture, but it does query each item and report if present,
I "think" that is the deal that is rain sensor and bi-xenon control
Cheers.
Savcom
Torque is great, it does everything like that very well. Plus some of the cheap ELM327 deals come with a CD of apps, and there is an APK (Android app install) for Torque that is full version, for free...
Going to have to get the car hooked up to Star/DAS.
tn
Can you do push notifications with the generic interface?
1 - 17 of 17 Posts
