Does anyone have any experience/fix for this. I change the EGS sensor every couple of years but this keeps coming back. Im thinking of loose connection in wire now.
Anyone know where to source a harness side connector from?
Hi
You need a new lambda sensor before cat, upstream lambda.
Check the cable from lambda into ecu.
Yes indeed, many thanks for the reply. Sensor has just been replaced and all OK for a while, but DTC and MIL light reappeared.
Any details (pinout, routing...) of cables?
I suspect a breaking wire so perhaps a shadow harness will fix for good, but I'd need a new connector. Any ideas?
Thanks again..
