1999 SKL230. Replaced bulb with brand new one and nothing. Left side fog light won't turn on but right does. Checked fuse #9 and by removing it the other fog light doesn't work. I recently removed the cluster and am wondering if I messed something up in there? Possible? Any ideas?
Founding Member #2
Faulty wire harness/loom to affected fog lamp area? check for frayed wires?
I will have to check and see if the wire(s) is getting power to it up to the bulb. No burned fuses. I changed the light bulb and it looks like there is now way to attach it incorrectly but I will double check again this afternoon. Thanks.
