After winter drained my battery, my driver window won't work correctly. When I open the door first thing (in the morning or after the car sits for a while), the window lowers slightly (normal) and closes after the door closes. The window then does not work after that until the care sits for another while after being turned off. I did discover that if I open the door, turn the key (but not turn car on) with door still open, the window will open fully and then close. I get one operation and then the switch does nothing.
Since the switch does nothing when the door is fully closed, I can't perform a Window Reset because the switch does not open the window any longer.
One morning, I entered from passenger side, turned key (engine not running), and the driver window went down fully and back up fully and then nothing. So, I get one window operation and then that's it.
Searching the site, I don't see any situations like mine. I found lots of threads about doing a Window Reset, but I can't do that - the switch is not allowing operation of the window. The motor works, so I don't think that needs to be replaced. Wondering about DCM, but if I order, not sure whether I need to "code" it. I have no software.
Going to try to disconnect battery for a bit and then reconnect to see whether that magically helps. I am not hopeful.
Car = 2005 SLK 350
Passenger window works fine from driver and passenger side switches.
Car = 2005 SLK 350
