Hello,
I have a 1998 slk230 where the driver's side window will go down, but not back up when using the switch. The passenger window works fine. I can also get the window back up when using a separate battery power pack on the motor switch. I thought this might be the switch, but I recently purchased a new window switch. I'm not sure how to test the window switch so, I guess I need some guidance on what to test/check next?
Thanks!
Troy
Thanks!
Troy
