Driver side exterior door handle doesn't work
3149 Views 2 Replies 3 Participants Last post by  El_Toro_33809
Yesterday, my driver side door handle would not open the door. Today, I removed the interior door panel and inspected. Not knowing what to look for, I couldn't see anything.
What do you think is wrong? can I repair it? what parts do I need to order.
Pat
2000 SLK230
Sounds like the lock locating dowel has either broken off or the lock needs undoing & relocating. Not easy as your working in a tight area.
Interior handle works on a cable that also has a locating white clip that can break with age. On back of panel, check thats all good too.
Here is a link to how to remove the handle. You may discover the issue if you take it apart.
Pelican Technical Article - Mercedes SLK 230 - Door Handle Replacement
Tim
