1 - 14 of 14 Posts
drl's
How long did they take to arrive and is the color of the light the same or similar? did you replace 1 or both?
Took just over a week to arrive and they are now a nice match for the LED Headlights.
Give or take the same colour as originals (same part number too!) but brighter as I'd except.
They came as a pair so replaced both within about 15 mins.
Will take and upload a pic...
Pic not the best but managed to catch between flashes
So having suffered the dreaded crack / chipped Daylight Running Lights and quoted £520 from the dealer to replace....
£27.99 fix!
https://www.ebay.co.uk/itm/2x-Daytime-Running-Light-DRL-Fog-Lamp-For-Mercedes-Benz-C-E-Class-W204-W212-R172/223016632091?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
Literally took me about 15 mins to remove both grills and replace the LED units.
:grin:
This member @Tonyh61 would appreciate knowing how to remove the drl.
https://www.slkworld.com/slk-r172-general-discussion/541108-daytime-running-light-removal.html
Hi can you check your link is correct as i have just put vehicle details in and it says "does not fit your car". As they clearly do fit on your car and its the same as mine, slightly confused.
Registered 2012 R172 SLK350
LED Headlights
Hi note that you state that you have LED Headlights. Did you fit the bulbs yourself, and can you quote a part number/supplier?
Cheers.
£27.99 fix!
:grin:
Think I might buy a pair just in case.
One unit already has a very tiny crack which I filled with Superglue
Discussion Starter #13
Thanks for the info , purchased them and fitted on the last weekend, they work great:smile::smile::smile::smile::smile:
1 - 14 of 14 Posts
