On my driver's side door the panel that the handle is on is coming loose. It appears that the glue that held it down has worn and released the door. Any suggestions on the best way to re-glue or attach the door panel. I'm sure glue or 2 sided tape could work..but i want to ask the question here.
moving to the general discussion section
The DIY section is for already created DIYs only.
If your question pertains to a procedure in a DIY, please post the question in that thread.
Someone will respond if they can assist and answer your questions and
will point you to a DIY if one is already made.
take the door card off completely and re glue the clips back on I used a 2 pack epoxy resin from an auto parts store the type that is like 2 syringes connected together works fine (until you need to take the door card off again)
