1 - 15 of 15 Posts
Registered 2001 SLK320
Some of you may not approve of lowering the R170 but I love the lowered look so I did it. I already know how you all feel about these wheels so let's not go there; soon as I make a short 4 hour drive I'll have the new one in hand. Ride is stiffer but I like it, feels more connected to the road. It's roughly a 1.25 drop, # 3 pads front and # 1's rear. This is going to sound silly but if the front don't settle a little more I'll have to change the pads/shims but should I go up or down meaning down from 3 to 1 or 2 or up from 3? Not sure which one will aid in a lowering the front just a little more? Also if anyone can recommend a better shock do tell. I did the double din nightmare swap some months ago; it was a lot of stuff considering most of all the original interior parts were either broken or cracked all to Hades!
(Don't Barf is directed at the bling! bling! wheels, if you want them let me know) since they are 3 piece wheels I may be able to replace the centers with something more appealing just to do something different.
Who cares what others think?
You've paid you money, worked on the car and are getting it as you want. How it should be.
These are low enough for me.
One thing:-
"Also if anyone can recommend a better shock do tell."
Better in what way?
Softer/Harder etc
Premium Member 2002 SLK230K
I went with the H&R sport springs with #1 pads all around, lowered the car about 2 inches. Rides hard and tight, very happy I did this mod.
Im lowered on D2 RS coilovers, about a 3/4 inch drop. i think the car will look much better after the wheels are changed. as others have said though, it's your car, do what makes you happy. with the new wheels that will be going on, i suggest leaving them the factory color, no need to repaint them. i've run 18" wheels on my car, this was before the coilover, when I had just h&r lowering springs, IMO with non-stretched tires, 18" wheels are slightly too big for the r170, making it look almost like a toy car. I currently run 16" wheels (same diameter as factory) but with a slightly smaller profile tire than factory. as it sits now, it's a very aggressive fitment but looks fitting
Thanks for the warm responses, SLK owners are really great people! SirClass, I would love to see your car. Is it possible you could send me a few pictures? Avel Du, I do not drive as if I'm on a track and there aren't many canyons around where I live for me to go topless through the twistiest. This said, I want a functional shock which will complement the sport H&R springs and It wouldn't hurt if it was a bit softer than what I'm experiencing with the stock shock in place. Good call on leaving the wheels in their factory color. I thought about it, did some digital fitting with a avatar car of my same color and I like the stock look/color better. I thought to go with # 1 pads all around but some one running the exact tire sizes recommended # 3's front and # 1's rear so that's what I did. Once I get my new shocks I may pull the springs and slip the # 1's on; then if I don't like it then I'll change them back. I have the Mercedes telescoping spring tool so it's pretty quick and easy to do. I've had my car for some time now and It sort of grew on me. I've thought to go test drive a new one but I'm afraid I may like it and wound up with a car note. I only feel this way when my alarm goes off for no reason at all on a completely dry day when it hasn't rained in weeks! It drives me crazy. I finally pulled the fuse and was done but I don't have interior lights now. Thanks again all!
2007 SLK350 fastdawg
I like the lowered car, looks very nice. Not sure about the wheels, too much metal, but I like chrome so maybe it's a wash. Nothing wrong with making your car your own! Because it is! :smile:
here are the stages my car has been in so far, with the different wheels and lowering
This was with 18"AMG wheels, normal tires, h&r springs, no roll or pull yet on the fenders
Last summers setup. D2 RS coilovers, 18" BBS LM rep wheels, stretch tires, rolled and pulled fenders
current setup, same as above, except these are 16" wheels with a meatier tire
the specifics of each setup regarding wheel sizes (diameter, width, and offset), spacer(s), tire size and all that can be provided too if you'd like lol
What's the offset on the LM Reps?
FYI this thread is 2 years old
First please update your location and vehicle (Put Looking!)(year?: 1996-2017, model?: 32, 43, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
1 - 15 of 15 Posts
