My driver-side dome/map light went out. At first I thought it was the bulb so replaced with a brand new one but it's still dark. The passenger works fine. Any ideas? Do they have different fuses and where can I find the fuse box.
Many thanks
New SLK owner here.
Please update your location in your profile as it helps the members answer any questions you might have based on locale and model.
usercp, edit your details, location.
do you have a manual? it shows the fuse locations. if you don't try here:
http://www.mbusa.com/mercedes/#/servPrtsOwnersManuals/
And finally, if you find something useful on your visit here today, please consider donating to offset development and operating costs. Even $5 is welcome! Thanks!
Fixed. Turns out the bulb holder is held down by clips and one of the clip was broken so the metal pongs were not making contact to the power rails. I jammed a piece of plastic in there and it's shinning bright now.
thanks for updating your vehicle.
location?
ty!
Had the same issue with my dome light. The plastics seem to be very thin and fragile and brake easily, especially the ones holding the conductive metal blades . Had to use epoxy glue to keep everything in place and now it's working fine!
