1 - 16 of 16 Posts
· Registered
All,
I've recently purchased a 2000 SLK230 (74,000 miles) that I love! I've fixed a couple of minor problems with it but can't seem to solve my problem with my dome light.
The dome light will not turn off when the doors are closed. Here is what I've done so far:
- Dome light switch in center position (turns off completely in right position)
- Checked door switches - replaced both to be sure.
- Checked all fuses
Is there another switch someplace that I'm missing?
Don
· Founding Member 2006
Moving to r170 general discussion section
New members and guests should be aware that the 'New Posts' link next to the 'Search' link top right of the info bar is a great way to see all of the posts you have missed since you were on the forum last. Remember to click 'mark forums read' under quick links when you leave.
Thank you,
Moderator/Founding Member
· *Registered
2019 SLC300
The switch if I recall has three positions on the 170. one for off all the time, one for on all the time, and one for when doors are open. Once door is opened and closed there is a delay in the lights turning off. You might be aware of the above just want to make sure. If you understand this and then you must have a problem that maybe some other member can help with.
· Registered
Discussion Starter · #6 ·
Checked PSE
Thanks. I've now checked the PSE and found that it is dry and all connectors are clean. Everything else is working fine on the car.
If I lock the car up, the dome will go off after about 30 minutes but will never go off while driving the car.
· Registered
Discussion Starter · #7 ·
Dome Light - New Information
OK...I read the manual. It says that if you leave the doors open, the dome light will turn off in 5 minutes. Additionally, the same page says that after closing the last door at night, the headlights will come back on for a few minutes for security - mine has never done that.
I put an ohm meter to the door jam switches again and found that the passenger door jam switch wires shows a short. I followed the wire as far as I can and it all looks good. Another forum mentioned that it could be a Combinatin Control Module problem but everything else seems to work fine.
· Registered
Hello! at first, sorry for my bad english ;) I've read the discussions about the interior light staying on..i have the exact problem, I've tried lots of possibilites that are causing the problem, but I haven't found one yet. I checked PSE also, but everything seems to work fine. Have you found the sollution yet?
Best regards from Slovenia,
Nejc
Nejc,
· Registered
Discussion Starter · #10 ·
2000 SLK230 Dome Light Switch Fixed.
Nejc
I did get it resolved, although I don't know how. It just started working again.
Don Pagel
[email protected]
There is something to be said about luck. I wish mine would start working..
Mine however does not have that pump in the trunk unless I have to dig deeper.
it is a diesel E300 1995 with 220K on it. Thanks for the hope.
Bruce
Bruce, see your private message from me on your question in other thread
· *Premium Member
2003 SLK230
When I had this problem with my old 230 it turned out to be the switch for the boot light.
Mark
Sorry to revive an old thread, just wanted to add, I had the same problem, but rather than the dome light coming on fully it was just on really dim. I had removed all the boot trim to try and fix the roof, which included removing the boot light. However, the contacts for the boot light were shorting through a bit of the chassis, making the interior dome light turn on! After separating the contacts in the boot, my dome light is now back to normal.
Thanks,
Dez
· Registered
Check the trunk light switch...
1 - 16 of 16 Posts
