Replaced my K40 and have a new PSE pump.
Dome lights work properly when switched on manually and when I unlock or lock with key fob.
Dome light auto-dims correctly.
Dome light does not come on when either door is opened .
Trunk light does not come on when trunk is opened.
I doubt both door and trunk switches are bad.
Any ideas?
did they work before?
check fuses?
check fuses?
As long as I've had the car there where issues with the door locks and lights.
That's why I replaced the PSE.
Now the key fob operates lights and locks as it should.
Checked all fuses and, as I said, the key fob unlock function operates interior dome and trunk as it should.
Manually clicking the switch on dome to "on" operates dome as it should.
Still though, neither door or trunk being "open" turns on dome or trunk light.
Premium Member 2004 SLK200K
Is the PSE the correct one for your VIN ?
If you've replaced with the same model you had before, maybe a previous owner had used one that wasn't right one, hence always having problems...?
Is your roof operating normally?
For the trunk light, there should always be +12V on one side of the bulb - can you confirm it's there? That should narrow down the culprit.
