1 - 8 of 8 Posts
Looking for a source to buy just the clear plastic lens cover? This is for a 2009 Slk 350. Any suggestion? I’ve tried online website without any success. Part number is A171-825-04-10 158 506
Thanks in Advance
Jim Mason
Jim, where did you get that part number from?
I got it from the side of the dome clear cover which is what I need. Actually passenger side light. Previous owner used some type of chemical that discolored lens
that is too many characters for a part number
post your vin if you don't mind or look here
https://slk-links.neocities.org
Registered 2007 SLK350
I've looked for replacements as well for the same reason, but with no luck. I ended up using rubbing compound on them that I had in the garage, and that worked well enough. I'm pretty sure I could get them looking new if I spent a little more time on them.
1 - 8 of 8 Posts
