61 - 80 of 81 Posts
Founding Member 2006
did u try the mb produced video?
Fantastical!!!!
what step did u do wrong or forget so others will be encouraged?
2005 SLK200
Well now that's the thing.....:laugh: :laugh: :laugh:
I don't know!! :surprise:
The 12.0v screen popped up at some point in the proceedings >:D
And then I knew I was in :nerd:
I love this forum me :laugh:
:grin:
Hi Guys,
Just getting used to my newly aquired R171 SLK and thanks to the help from forum members have managed to change the panel from German to English so I understand the messages coming up.
When I check for next service it says "Service B in 11595Km"
When I open the door and the panel lights up it says "1 MALFUNCTION" when I use the arrow key it tells me "MAIN INSPECTION PERFORMED ON TIME ? " and a Spanner symbol.
It won´t disappear on its own and not sure what action to take to correct it.
Appreciate your help, advice and experience on how to remove it. :smile:
Hi Guys,
I take it you don't want to reset the service indicator ?
If you enter the " Main inspection performed on time ? " do you get a yes or no option ?
Hi Curro,
Many thanks for your reply and interest, - my friend you are indeed the guy quoted in Bold in my members reference above regarding the language change and a credit to the forum for the way in which you help others.
I do not get a Yes or No option.
I am uncertain what logic the panel is working on.
The question "Main Inspection performed on time ?" looks as though it might require some form of confirmation. When I press the arrow buttons it just toggles between this message and "1 Malfunction" . the + and - buttons do nothing and changing menu just takes me somewhere else. !
Equally not sure what the term "Main Inspection" is refering to in this instance.
Since the service reminder seemed to be logical in its forecast I was unsure where to look or whether a Reset was the correct solution. !!
It`s one of these situations I did not want to do one thing and then upset another if you know what I mean. There is a solution I feel sure, but not sure what it is at the moment.
Thanks for any idea`s.
Kind regards
Dennis :tu: :smile:
2004 SLK200K
Thanks , I just try and help out others as I would want them to help me , it's just the way my mother brought me up !
I've never come across this message unfortunately , as I don't use the buttons for service resets , because I have access to a DAS diagnostics a friend has and I use that ...
Have you tried using the "R" button on the side of the cluster when the message or the 1 malfunction sign is up ?
You could always try a battery reset , removing the negative for 30mins or so to see if that sorts it ...
Thanks Curro, efair & Jeff,
Nice one Guys. Job sorted and have set the reminder to 12/2040 so it won`t be bothering me again. I will be doing all my own work so will be working to my own schedules and due dates. It`s just good not to have this nagging symbol there all the time.:tu::tu:
Thanks for your detective work Curro in leading me to the solution, hope I can help you or others in due course.
Regards
Dennis :wink::smile:
Registered 2016 SLK55 AMG
Thanks to everyone who posted info!
You guys are AWESOME!!
After about 45 days I finally got this sorted out... :)
Reactions: jbanks15
Do we use these instructions to reset the service B (13000 miles)? I've located 4 different ways to reset service indicators and so far none have worked. I have not tried this one however but it is also more in-depth and require more information like grade of oil used? I am not 100% sure the weight of the oil used but I do know its Mobile 1.
Should reset any 'current' service A or B or whatever
* Registered 2005 SLK350
Gents, this is posted in the public domain by MBUSA, and is not marked as copyrighted, so I think it's safe to keep a copy here for reference.
http://www.slkworld.com/2327714-post50.html
Wow! After 8 years, UC-C200's post is still helping us out! I had this irritating service message come up for 2 months now. After finding the post, I downloaded the .pdf and followed the sequence of button pushes/selections. After, 15 minutes of trial and error interpreting and using the buttons, 'voila!' the service indicator has been reset!
Thank you UC-C200 and forum!
ccslk
ccslk
can we get you your free gift?
Tried to use this instruction several times without luck, instead of "Service Confirmed" I got "Service not Confirmed"
But after the activation of "Cancel Service" (the action below the Confirmation) I could follow the instructions and succeeded!
2007 SLK350
Another happy customer of the original post.
B-Service re-set no problems, and also found the Voltmeter I never knew I had :smile:
61 - 80 of 81 Posts
