1 - 9 of 9 Posts
2005 SLK280
As above:
Tools required. 16mm socket or 🔧 for removal
T30 torx bit.
(+ a suitable puller).
First jack and support car then remove wheel.
599238
Drive rear pin out of caliper that holds the brake pads and spring plate in place(make a note of how spring plate goes back on,to save confusion when refitting ;)
599240
Remove brake pads.
599241
(at this point you can use a suitable tool to push pistons back in on caliper) better to do it against old disc before replacing,be careful not to damage the piston seal.
(You may require another tool to hold opposite piston ,stop you playing ping pong!)
599243
2 x 16mm bolts hold rear caliper in place,have a block of wood handy or something to rest caliper on once removed.
You may need to back the handbrake adjuster off inside the drum if its worn or difficult to remove disc, this is accessed through a wheel bolt hole.
599244
Adjuster with disc(rotor) removed.
599245
Remove the T30 torx screw that holds disc in place and remove disc
599248
Depending how worn your discs/drums are ,you may require a suitable puller to remove them(as I found out!)
599246
Check your handbrake shoes and mating surface, give everything a good clean with brake cleaner..clean your new discs as most will be covered in a packing fluid.
Your good to reassemble!
599252
remember to adjust the handbrake adjuster back up till it bites,then back it off slightly so it's free to rotate.
Use thread lock on your 16mm caliper bolts( use correct torque setting)and the T30 torx screw that holds disc in place.
Give your brake pedal a couple of pumps until it feels solid ,check that it still rotates fine.
Refit your wheels,torque bolts correctly.
On to the next side!
Wheel bolt torque setting for 16 and 17 inch
80ft-lb /110 Nm
Caliper mounting bolts 40 ft-lb/55 Nm
2007 SLK350
Thanks for a great write up and clear pictures. Are you able to edit and add in the correct torque settings for the caliper and wheel bolts so others don’t need to go hunting ;)
@i860 I think you have the torque settings.
I can remember wheel bolts are 80lb/ft but not the others.
2006 SLK200
Great guide.
Just a quick question though, did you have any problems removing the caliper bolts? Access to mine are blocked by a suspension bar (the black one you can see behind the heatshield at the 12 o'clock position in your last photo.
Great guide.
Best to quote (as I have with your reply) or mention (as I will for you now) the member that you hope will reply.
@Slik hot
Note that there are several other brake diys that may contain the answer to your question.
2005 SLK280
Discussion Starter · #7 ·
Great guide.
Hi
Caliper bolts are simple to get to,you may require a small wobble bar to make it easier for yourself (y)
2005 SLK280
Discussion Starter · #9 ·
As I said, mine are blocked by a bar so it's impossible to get a socket onto them so I will have to find another way
Use a spanner if you can't get a socket on them,or undo the anti roll bar if that makes it easier.
1 - 9 of 9 Posts
