I recently purchased a 2000 Mercedes Benz SLK230 Kompressor. It needs new engine mounts and a new transmission mount but I haven't seen very many step by step instructions on how to change them yourself. Is it very difficult? Do you need any special tools to do it? And how would you do it?
moving to the r170 general discussion section. the diy section is for already established diys. if there is a diy, someone will direct you to it in the diy section
Moderator/Founding Member
as far as diy motor mounts, head for youtube and type motor mounts for videos. unfortunately, none are for the slk but will give you an idea.
Probably not very different from other Mercedes mounts. Check out the 210 chassis forum on BenzWorld for example for some DIY threads on mounts. Let us know how it comes out and what your experiences are.
