1 - 20 of 24 Posts
Premium Member (Previously 2012 SLK250)
I recently changed the grill on my R172. In that connection, I had to mount over the two radar sensors to the new grill. The aftermarket grill had a slightly different bracket for the box that holds the radar sensors, so a little modification to the boxes where needed, but I got both fixed in position.
After the first longer test trip, I discovered that Distronic Plus did not work properly. At higher speeds than about 70 km/hour it worked, but at lower speeds it does not work, and Driving Assistance where notifying too short distance to the car in front, without any car in front of me.
My theory is that when one moves over the radar sensors they will never get exactly the same position as they had, and that the system detects that deviation. If so, it may be for security reasons that the system disables Ditronic Plus. Then why does it work at higher speeds? As I understand it, the two satellite sensors in the grill work at a lower speed. among other things, they will catch obstacles as pedestrians and when approaching a car in front of them (the last meters).
At a higher speed I have understood that it is a sensor in the radar itself. The radar that sits directly behind the star in the grill. It is not stuck in the grill, so I have not made any changes to its position.
I wonder if anyone knows if the error may be that the radar sensors must be calibrated against the radar because they may have changed position? Or could it be that when disconnecting and reconnecting the radar sensors, something has to be reset in the brain of the car? I do not receive any error messages from the dashboard after starting the car. Only a message that the system disconnects from Distronic Plus, after trying to use it at a speed lower than about 70 km per hour.
I called Mercedes and asked, but they were very unsure and just want me to book an hour (or five ?) for troubleshooting. Thats why I try here in the forums before letting the stealer ?sorry, the dealer try to fix the problem.
The dealer is going to tell you to put the original front end back on. How much were the sensors moved? Are they still aimed exactly the same? Is the radar patch blocked more now than it was on the original? My guess is that it is hitting something on the new bumper and it thinks it is an object.
Initially, the radar sensors are positioned just like the original, because there is a molded field in the new grille, with clamps where you squeeze the box with the radar sensor into. Of course, it may be a few millimeters different because it is jammed inside the grill and the grill is fixed to the bumper. In addition, an isopore piece is added to the entire same field on the inside of the grill. When the bumper with the entire assembled "choir" ???is to be mounted, it will end up with the difference of millimeters each time one disassembles and reassembles the bumper. These two "satellite" sensors cannot be physically / manually calibrated when the bumper is screwed into place. It may be possible to electronically calibrate them against the "mother control" / radar in the middle, behind the star (which also has its own sensor). The radar itself has not been changed on the fact that it is screwed straight into the body of the car behind the grill and bumper. That part is untouched by my hands. As for whether the grill itself is in a material that the sensors capture as an object, I have been thinking about it. Therefore, I asked the supplier if other customers have experienced problems with this grill when mounting on SLK with Ditronic Plus. This is the answer I got. Of course, I know nothing about the reliability of those who responded:
Thank you for your e-mail.
We have not experienced any issues whatsoever with mounting of these grilles to models with Distronic / Plus. Therefore, we cannot fathom why you would experience any problems.
No other customers have expressed any issues either.
Regards,
CKS Performance
Maybe in xentry you can recalibrate the system.
As I wrote above here, you cannot physically / manually adjust the two "satellite sensors" because they are on the inside of the grill and bumper. No access or adjustment options when in position. They are fixed.
Thats why your input is one of my hopes, that a diagnosis and possible electronic calibration, or a reset in the brain of the car will fix it?
In regards to re-calibration, it appears that your MB dealer can do it.
This is in regards to an E-class wheel alignment issue but it address's your re-calib issue
Reactions: LatinViking
Thanks. Looks like this most likely will be the next step ?
I am taking about xentry adaptation. You need sd connect c4
I do not have such equipment, so it is most likely a trip to the dealer that will be the next step. Thanks :)
I have received many good suggestions. I appreciate that. Have decided to "crawl to the cross" ?. Time is booked at the Mercedes dealer on Monday. They will start with a check of "the brain of the car". I'm excited about the outcome. I will come back with a possible answer or result after this meeting :)
What I need is a control that sets the speed of the car in front of me.
That's exactly what I want too. It's just that that feature is temporarily out of service ?
Reactions: SLKomatic
Discussion Starter #12 (Edited)
I have been to my Mercedes dealer today, who I know very well and who is very reliable. They did not find any errors in the diagnosis, but they found the same errors as I have pointed out as a reason why Distronic Plus does not work. They checked and saw that the radar sensors were at the wrong angle due to partially detached (sensor box) from one of their fasteners on either side. After dismantling the bumper, they/I registered that it is not possible to mount the parking sensors in any other way. They saw that the end of the parking sensors was causing interference to the radar sensors and that it made it very tight to depress the radar sensors. The clamps to hold the radar sensors are not strong enough and the placement of the tendons partially over portions of the parking sensors works poorly. Compared to what the supplier has claimed, this is no "plug and play" grill when you have Distronic Plus. My Mercedes dealer said they were willing to try to modify, but they could not guarantee either the result or the durability. With so many unsafe cards, I made the decision that they could reinstall the original grill so everything could work properly, and it also did so, after retrofitting the original grill. I have sent a complaint about this to the supplier and I wonder if they take responsibility for selling something that does not work. There have been about 800 euros in total (grill, shipping, VAT about 300 euros and work about 500 euros) out of the window so far, with the price of the grill and for the mounting jobs :mad:
I will return with the result in relation to whether the supplier takes responsibility or not so others can learn from my experience :giggle:
The good news is that the car works with all the radar features again (after retrofitting the original grill). Function takes precedence over aesthetics ?
Premium Member 2013 SLK350
Awww... sad to see the outcome of this new grill on your Distronic Plus feature. But you made the right decision to revert back to stock grill.
Discussion Starter #14
Appreciate the support. It seemed so raw with that grill. I'm disappointed, but the original is classical nice in its own way. It does not help to have a beautiful partner, if all the "aftermarket products" ruin her for her healthy and good functional capabilities. Without comparison ?
Registered 2013 SLK55 AMG
thanks for flagging this and sorry you had problems but you have helped me make my mind up. I was going to swap to a new CKS grill but couldn't work out which one. I now won't, my car remains original !!! :)
Discussion Starter #16
That's good my warning works. Do not want others to have the same problems and lose as much money and time as me. So you also have Distronic Plus?
Discussion Starter #18
I do have distronic plus
I did not think AMG had Distronic Plus, because I read that the first editions of R172 AMG did not came with this. So that means they were delivered with Distronic at a later point.
Discussion Starter #19 (Edited)
I promised to come back in relation to whether the supplier took responsibility for shipping a product, which does not work.The supplier is CKS Performance.
The thing is they have sold me an AMG-GT grill (for R172) that does not work on cars with Distronic Plus. Thinking the same will apply to the diamond grill they sell for the SLK R172. The reason is that the radar sensor attachment and the parking sensors attachment are designed so that when the parking sensors and radar sensors are mounted, the parking sensors come into conflict with the radar sensors. Distronic Plus will then not work and turn itself off.
There is nothing on the supplier's side, that the grill will not work on the R172 with Distronic Plus. When I told them about the problems, they replied that they had not had anyone else with this equipment who has had trouble making it work. Later, I got Mercedes Benz to troubleshoot, and they came up with a clear statement that matched what I myself suspected. They also said that the grill needs to be modified to make it work. At the same time, they said that they could not guarantee either the result or the duration of a modification.
When I confronted the supplier about what Mercedes Benz had concluded, they changed their answer. They were soon out to provide input on how it could be done and modified to make it work. Suddenly, they also realized that this grill is not a "plug and play" out of the box for cars with Distronic Plus. The suggestions they came up with made me feel as a guinea pig in their way to try to find a solution. I told them that I did not want to continue on this project and I challenged them to take responsibility for selling me a product I cannot use straight out of the box.
My total costs of buying the grill, VAT, transport, freight forwarder, troubleshooting, mounting and retrofitting by Mercedes Benz came to a total cost of about 800 euros. CKS Performance gave me two choices.
1. Return the grill (the transport back I would have to pay from Norway to England). It is a requirement that the grill should be in exactly the same condition when they receive it as when they sent it. In that case they will refund the net price of the grill which is a bit over 200 euros. If I had gone for this solution, and paid the transport back, then I would have ended up with a return of just under 150 euros for the grill in reality, and only if they had accepted the return goods. If not, I would have gotten zero back, and must have added the approximately 50 euros (transport etc.) on top of the 800 euros in wasted money.
The rest of the costs they would not take any responsibility for, referring to the terms and conditions on their pages (which few read, but should read). This terms states that the buyers has to pay all transport, both home to themselves and in the case of return of goods. It does not matter if the buyer receives a faulty item or an item that does not work. For whatever reason the buyer must take all the costs of transport and in addition they do not take responsibility for the costs the buyer has for assembly / disassembly, taxes, toll etc. regardless cause.
I have never in my 54 years seen a company with worse terms of service and can not really understand that it is possible and legal to set such horrible conditions. In this case, however, there will be a violation of the Marketing Act. They have marketed an item as an item with greater characteristics than it really has. And important information / limitations with regards to the item are retained. This I confronted them with. There was no response or interest of taking responsibility to this.
Then I had the other alternative they gave me.
2. They said they wouldn't admit any mistakes, but they would, as a good will :LOL: ?, give me £ 50 if I kept the grill (which means I have to sell it myself in the used market). Since that solution most likely limits my loss to a greater extent than the first solution, I went for it. If I'm lucky then I'll be left with 250 euros of the 800 euros I've spent.
My experience and conclusion about the service of CKS Performance is as follows. Their formal service conditions are the most horrible I have ever seen and experienced. Their willingness to take responsibility is the most pathetic I have ever experienced. The solution I ended up with is absolutely ridiculous. Will I buy from them again or recommend this provider to friends? NEVER :(
You know, I sympathize with you 100%. No one wants to lose cash or product because of "issues".
In view of that, I bring this
to your attention. Now, that is US and not Norway or UK (or where ever they are) so laws may/probably are different.
I just want to ensure that in your displeasure, you watch what you post.
1 - 20 of 24 Posts
