About this time last year I took my 1997 SLK 230 in for it annual MOT during which the following advisories were noted:
As for this years advisories I do find it strange to get an advisory noting that the car was designed and built with several removeable under shields. To be honest the play in the front wheel bearing is fair comment. I had noticed that and had fully intended to put the dial gauge on and check the end float but it slipped off my stack of jobs. So I have to agree with that one.
- Offside Rear Upper Suspension arm pin or bush worn but not resulting in excessive movement
- Nearside Rear Upper Sub-frame pin or bush worn but not resulting in excessive movement
- Front Coil spring corroded O/S/F and N/S/F
- Rear Coil spring corroded O/S/R and N/S/R
- Under vehicle covered.
- Slight play in both front wheel bearings.
- Fix a leaking vario roof cylinder
- change all fluids
- fit a new K40
- retrofit an auxillary coolant pump
- clean and lubricate both side window regulators
- a shed load of cleaning and polishing...
