1 - 13 of 13 Posts
Wizard of ID
I think it was Designo who posted a DIY on changing differntial fluid. I'll be darned if I can find it now. It was a great post. Anybody help me find it?
If you can find one of these from the ponton days, they really are nice.
Len
Mercedes-Benz Ponton Tool Kits © www.mbzponton.org
Original style 14 mm hex (Allen) wrench:
The original Mercedes-Benz Ponton 14 mm hex (Allen) wrench (120 581 06 65) is used for the following drain plugs:​
  • differential (both drain and filler plugs)
  • gas tank
  • oil pan
  • transmission (both drain and filler plugs)
Wizard of ID
Len
  • gas tank
  • oil pan
Now THOSE are cool!
Would using Castrol C Hypoid 80w-90 be okay for use on the diff? It is also GL-5 rated gear oil however I don't think it is synthetic.
Just did this today. Whole process took about an hour. I had to raise the back of the car a little because I couldn't get enough clearance to swing the rachet to break the plugs free.
Like the pdf author says; Make sure you use a hammer to make sure you've got the hex bit well seated into the plug. They seem pretty easy to strip
I had to order a 14mm hex...cost me $15, and a lot of screwing around, but at least I have it now.
I used a 75W90 full synthetic gear oil.
I didn't have a fluid pump...So I stuck a piece of rubber fuel line on the end of the bottle (similar bottle to the one pictured above) and fastened it there with a hose clamp. Worked like a charm, there is a good space just in front of the diff you can use to position the bottle.
1 - 13 of 13 Posts
