Registered 2005 SLK350
One of my hoses to roof hydraulics broke. Fixed it now deck lid won't close. If I release pressure to pump still won't close. But opens fine and deck lid will close. Suggestions? Thank you.
587727
Administrator/Founding Member since 2006
1st post should be your intro:
Post an introduction.
Go here:
Did you try lubricating the mechanism?
Your post is confusing, please edit it to eliminate the contradictory statements. Do you have any idea why the hose broke? The cylinders can seize up, causing irregular motion.
If you've exhausted all options, remove and send the cylinders out for rebuilding.
Registered 2006 SLK350
how much hydraulic fluid did you lose in the process of all of this? if you are low on fluid or have a line full of air it's not going to work until you refill the reservoir and run the pump in either direction a few times to purge the lines.
