Long-time lurker, first time poster! Just bought my second r170 yesterday, which unfortunately won't start today...
Upon turning the key into position 2 (the "run" position), the whole dashboard illuminates and engine cooling fan comes on at max speed. I am fairly sure I can hear the fuel pump prime. Position 3 will not engage the starter. The battery is charged btw.
In my testing I have sent 12v power direct to the starter motor which turns over fine. All the pins in the engine relay module (part no. A1705450105) appear to have the correct voltage at the respective key positions, except for the send to the starter motor, which doesn't get 12v when the key is turned to pos. 3. Am I right in assuming that putting in a used engine relay module, A1705450105, from ebay should rectify the problem?
Is it worth taking the engine relay module apart to have a look at/solder? Should I have a look at/replace the K40 while I'm at it - just seen a lot of talk about it on these forums!
Thanks Guys!
Thanks Guys!
