2007 SLK 55 AMG
My dashboard clock is wrong!
From memory, the clock can be changed via the Head Unit - problem is, I've changed my Head Unit to non-Merc.
Is there any other way to change it, or will I always be 36mins late??
Super Moderator (Canada)
2012 SLK55 AMG w/P30 "Schwarzie"
what happens if you disc the battery then wait and....? What time shows up once re-connected?
If it re-starts at 12.01 am, then you have a late evening awaiting you for "automatic" time correction 😉
2019 SLC 300 Black on Black
If I remember correctly you can set the clock using the button on the steering wheel. In the display above the steering wheel in the submenu, you should find the date/time menu. Check owners manual page 141 & 142.
