1 - 20 of 208 Posts
Premium Member 2004 SLK350
Hi
I installed today xentry/das with vas5054a ( not sd connect c4 ) device £55 ( a chap from California ), and we tested on a c230.
It has the full functionality of my £500 sd connect c4, take 2 days but what a great result.
Moderator addition-->Per a PM I sent re equipment needed (at post 13), reply received: You need a vas5054 oki chip, a laptop with windows 10 or 7 64x and i can do the rest remotely.
Premium Member 2005 SLK350
Hmm. Interesting.
Remember Myk as good as Das is it will tell you whats wrong and point you in the right direction , clear codes ect
But it will not pull the car apart and hands on fix it for you......but will leave you with that nagging thought of
Now I know my car is xxxxxx >:D>:D>:D>:D
A cheap OBD reader from euro parts ect is a handy little thing to keep in the boot for road trips ect ( turn light off limp home )
Actually is £58 just order one now.
That is the hardware is a pass-thru device instead of sd connect c4 and then you need the software. The newer the car the better.
Next week I will receive my device, install all software and do extend testing gon my 2 cars.
Again if an old c230 can be read ( all modules, air bags ezs module ) plus the ability to do all the testing and actual startup on modules.
Just finished a 1h session ( in California ) playing with this and very impressed with the cheap obd tool. So far seems to see/do exactly like sd connect c4.
Excellent, I had been looking at the bigger kits but if this will do what I need that is great! Thanks for the info.
Registered 2009 SLK200
Is this only for merc connection only or other manufactures ?
Discussion Starter #20
Vas obd arrived today, I had all prepared windows with xentry/das and I test it on my slk and my w204 c280.
As you can see all the module can be read and accessible.
So anyone can own a star system now.
If you are for it buy the vas obd oki and I can help you with the installation, please PM me for more info.
DAS
Xentry
1 - 20 of 208 Posts
