Am I correct in assuming that 2004 Chrysler Crossfire 320 clocks (speedo, rev counter etc) will fit a 2001 SLK 230K.
I've seen some black ones which would nicely darken Hecate's interior.
I know the heating, A/C dials can be swapped, but I'm unsure about the clocks.
IIRC, they may be. Try a search on someone modifying the instrument panel of the R170 with that from a Crossfire: it may have been someone from Las Vegas, Nevada.
Cool. Will have a search, although searching for Crossfire previously showed very little. I seem to have worse luck with search than anyone else :(
Found several threads which suggest that early Crossfire was almost entirely R170 and several suggesting clocks can be swapped.
Will buy the clocks and see if they'll fit.
see if you can find old crossfires at a junk yard
