Does anyone know at what temp. the cooling fan comes on? I also could not find a fuse for it? Thanks for your help.
Moving to r170 general discussion section
I have asked this, don't recall getting a response. However, on mine it comes on shortly past the 80 mark when the AC is on. If I have the EC button pushed (little light is on), then it doesn't come on to close to 90. Don't know if that's what it should do, but mine does.
ref
According to the information that I have it is 80C (approx 180 degrees). I do not believe there is a seperate fuse for the cooling fan. You did not indicate what your problem is.
I got hung up in traffic the other day and the temp got up to 100C. I was a little concerned that the cooling fan did not come on. As I had the top down the A/C was not on. Does anyone have an electrical schematic of the 1998 SLK 230?
have you checked leapyfish's signature block for links?
