Hello All,
I have a great SLK320 2002 that I want to convert from automatic transmission to standard.
Anyone has a list of what needs to be replaced?
My list is:
- Transmission box
- clutch
- pedal mechanism (gear pedal and brake pedals along with the body holder.
- clutch wire
- shifter
What else? things I suspect:
1- computer unit (which one? how many?)
2- shaft??
3- cruise control unit??
Your help is highly appreciated!
Founding Member 2006
If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
Clutch master cylinder
Clutch slave cylinder and necessary hydraulic tubing
Shifter
Shifter surround
Shifter to transmission linkages
I'm not sure but you might have to change the transmission mount on the cross member
Flywheel and bolts
If you order a clutch kit, make sure it has the transmission input shaft support bearing that goes in the flywheel. Some kits have it and some don't.
The bellhousing that Idiot101 mentioned
I might be missing more needs.
