1 - 18 of 18 Posts
Greetings! My name is Craig from Florida and am considering purchasing a 1999 SLK230 5-speed manual in Blue. Carfax shows a one owner with all Benz dealer service throughout its 89,000 miles. Car appears in fantastic condition aside from some center console paint wear.
Up until now I wasn't considering a Mercedes as I was in the Market for a Mazda Miata when I stumbled upon this super clean SLK that I can actually afford. This purchase is a "Toy" for me as my daily driver is a company vehicle So it'll only be used for fun.
I have been reading the forums and sense the early SLK 230's were problematic? If so what specifically should I be concerned about? I intend on having this SLK inspected at the local Mercedes dealer prior to closing on the deal.
Has anyone owned a Miata prior to their SLK that can comment on the differences?
Craig
Premium Member 2002 SLK230K
Welcome from New Hampshire. The biggest problem is the K40 and some of the roof rams leaking, other than that just look for the normal wear and tear stuff.
Hi Craig. Where in Florida?
Thank you,
Founding Member/Moderator
Jeff, I'm up the road from you in Brooksville. Thank you one and all for the warm greetings. I'm hoping I can put together this SLK deal and participate in what appears to be a great forum and community.
Craig
Thank you,
Welcome from Michigan....
We owned a 97 Miata and then a 07 Miata prior to buying a preowned 05 SLK350. The SLk is a much more solidly built and more powerful. Also welcome from the East Coast.
Welcome from Phoenix i got a 99 Slk 230 with 54k on the clock and i luv every mile in it.
... If so what specifically should I be concerned about?
-Look at the headliner for wrinkles: it means the hydraulic locks are leaking. Parts: $300
-Listen (stand near the trunk) when you lock/unlock the car using the remote. If you hear the PSE running for a long period of time, it means there are leaks in the system or the thing is giving out. (door locks/trunk lock operated by vacuum/pressure). Parts: $300
-Listen for any rattling in the engine bay. While it could be a lot of things, it's more than likely either 1) timing chain, 2) bearings in the supercharger, or 3) valve train noise. None of the above are good. Parts: 1st born child.
-Take the car on the fwy and feel for vibration. While it could be as simple as a wheel out of balance, it could also be the flex discs on the drive shaft. They do wear out and about $200 in parts. It took me 4 hrs to replace mine.
Hopefully I didn't forget anything. The rest is obvious stuff as for any car.
oh, and Welcome from SoCal.
I own a 99 5 speed slk 230. All black with about 70K on it... I absolutely enjoy driving this car; it is in good condition and I try to keep it that way... I have owned four Miatas and currently own one which is sitting in Florida.. The SLK wreaks of quality by comparison and it is about as much fun to drive as the Miata.. I cannot criticize the Miata as it too is a fine car... If I had to choose it would be the SLK. You will get about the same mileage per gallon... dms
Discussion Starter #15
Value
OK guys, 89,000 miles....One owner with clean carfax. Center console has some issues. Is $8999 fair?
Craig
Thanks for writing about the wrinkled headliner, Todd. Until I read that I had no idea why my headliner was wrinkling more and more daily. I put my finger between the vinyl and the foam a few min. ago and sure as the world, my finger came back oily smelling of hydraulics. Better get it in before the silly liner drops on my head.
Cliff in KC
Premium Member 2009 SLK55 AMG
Welcome from Sacramento Valley SLK Enthusiasts!
1 - 18 of 18 Posts
