Connector out of tail light???
862 Views 8 Replies 5 Participants Last post by  Jet Wrench
Recently, I had some body work done that involved replacing the driver's side tail light housing. When I got the car back, there is a cable coming out of the slot with the brushes there by the tail light., The cable has an end on it like a cable TV that one screws on to a device only it is much smaller. Any idea as to what this would be??.....thanks......Dennis
1 - 9 of 9 Posts
Which side? There are sattelite and cell phone and fm/am components all in the back on both sides.
Is tour radio stock, and working OK?
Reactions: 1
It's not related to the tail light as that has only a single 6-pin loom connecting it to the car. I suspect it might be your antenna amplifier.
Reactions: 1
There was an option for a phone in the R170. The wiring was in place if the phone was to be added. That's what I'm guessing you are seeing.
Tim
Reactions: 1
The stock radio is working just fine. It has a CD player and there is some option for a phone in the radio.
The cable is on the left/driver side rear tail light area. The gizmo that one pushes up by the interior light works. I think that is the "SOS" thing.
It does NOT have a cell phone or satellite connected. How does one or can a person someway yes one's cell or add a Bluetooth functionality????
I've only touched pre-fl 170, no experience with newer. I don't think I'd waste time or money adding anything to the stock setup - just replace it. You might be able to reuse the amplifier but that's as far as I would go
Tim
So it's on the left side/driver's side and a cell phone or what??? what is the actual hardware/equipment?????
Yes it's on the driver's side. I've never seen the equipment, just the wiring for the hookup.
Tim
Reactions: 1
I've got one on my car.....
It's the antenna amplifier connector. My car is a Euro Spec 200SLK, and an external antenna was not used. The amplifier is mounted just below the brushes to the left. Sounds like it's time to look for another mechanic! :wink:
Reactions: 1
1 - 9 of 9 Posts
