1 - 20 of 20 Posts
· Founding Member 2006
Discussion Starter · #2 ·
· *Registered
2006 SLK350
If you change the conductor plate you need SCN coding, initial start-up, and adaptation on the road.
I'm likely going to have to do the conductor plate in my car. I thought I saw something about being able to SCN code it with an Android phone and a paid by use service over the Internet? Does anyone know if this is true?
I'd much rather do the job myself and I have a icarsoft 2.0 scantool if that helps. Is there a way forward to doing it myself?
· *Registered
2005 SLK55 AMG
Generally cheaper/easier to have repaired rather than swap...
· Registered
I had the conductor plate on my 2007 SLK350 sent for repair two weeks ago. Less than a week later it broke again; stuck in gear, same fault code. It has now been sent away for a 2nd time. I bought the car 4 weeks ago, so not impressed, especially as last years MB SERVICE INVOICE refers to a transmission electric plate fault, which was not repaired (software updated and customer to report back). Customer obviously shifted car onto a dealer and now I have it. Since the service it has doe 2000 miles; are there any secondary parts that could potentially be damaged as a result of the plate not being repaired last year?
· Banned
2013 SLK55 AMG
If you bought the car from the dealer I believe under U.K. Consumer law the dealer is liable to fix this problem as it was pre-existing and surfaced within six months of purchase.
TonyS
· *Registered
2006 SLK280
Conductor plate problem
Hi all,
So I have an odd problem that I have seen was an issue on the 722.6 transmission but I can't seem to find any information for the 722.9 having the issue too. I pulled my conductor plate today to send it off to have the speed sensors repaired and when I pulled the electrical connection it was full of transmission fluid. Has anyone else encountered this problem on the 722.9? does anyone know a fix?
Thanks in advance,
· *Registered
2006 SLK55 AMG
I just had a load of work done on my 55. I had symptoms of what I thought was conductor plate issues (stuck in gear etc) until it 'failed to proceed'. It turned out to be the CPS (when the codes were read). After I picked it up, I've driven the car hard (as I was happy to have it back) and the gearbox is honestly smooth as silk. I wonder if a CPS on the way out could cause the sensor in the conductor plate to get confused ?
Its just conjecture and based on absolutely no knowledge whatsoever, but just throwing it out there ?
Discussion Starter · #16 ·
what were the codes?
· *Registered
2006 SLK55 AMG
I can ask them next week, but the description on the invoice said :
EML Light on, carry out STAR diagnosis and record fault code data:
Fault stored with crankshaft position sensor. Test sensor and found to be faulty.
Replace crankshaft sensor.
Like I say, I'll ask them on monday what the actual code was. I just thought it odd (probably just coincidence, but the box has behaved the best it ever has in my albeit short time with it).
Cheers
Discussion Starter · #18 ·
i meant what made u think it was conductor plate?
· *Registered
2005 SLK350
Cheers
Hi and thanks for keeping us updated.Let me know about the codes. I will also see what is going on with mine soon and let everyone know.
1 - 20 of 20 Posts
