Premium Member 2014 SLK55 AMG
My GPS looses satellites and I'm pretty sure that it's the antenna itself or the connection to the control box. It usually happens after a visit to the clay pigeon club after a 1/2 mile of farm track ( at 1 to 2 mph I hasten to add ) the signal dissappears and will take either the return trip or a couple of days of driving on potholed Sussex roads to come back!
Found the GPS antenna behind the rear view mirror!
The GPS 'control unit' is contained within the DVD box in the boot I think.
Anyone know how to diagnose connectivity issues between the two? Is the GPS antenna a known problem?
i have a stack of GPS parts having worked on some other nav systems so I could probably fix or substitute whatever needs replacing.
Sadly Woolly has passed away
On an R171, it's just a straight (micro) co-ax cable from the antenna (in the mirror housing ), down an A-pilar to the back of the COMAND head unit. Unless you have a fault in the cable itself, the best you can do is check the terminals.
I won't preach to the afflicted, but, you're not parked up under any trees etc., that will stop the signal?
Nope no cover and it sometimes takes days to recover. Usually after a bit of rough road. I suspect it's a poor antenna connection because I monitor it in the hidden satellite monitoring page and get long periods of 0 or 1 sat in view. Using a handheld GPS at the same time I can usually see 8 or more above the horizon at the same time.
Evening..
Probably a duff GPS antenna or bad connection - may be worth popping the headunit (or DVD unit) out to check the connection
Cheers
Sean
aka John
Ah, it runs to the boot to the navidrive, not the back of the head unit, but otherwise all the above suggestions are valid.
