I have read through the posts but there are so many regarding different parts. I wanted to see if there was any common problems. I have had the window switch replaced but was concerned there may be more common faults. My 200 Kompressor is a 2009 model. I noted on the previous repairs that the suspension springs have been replaced. Is there some other major issues? Any replies would be appreciated.
Cam chain, rear subframe, battery box drain.
Super Moderator
As per nimbus, plus seals.
If they have been looked after, all good.
If not they need a good clean and gummi.
Ditto the drain holes.
If you don't make sure of drain holes, then the cabin heater (behind glove box) gets corroded.
Other than that, 10 year old car.
You want to be sure of what you have?
Go through the purchase checklist.
Thank you so much.
Thanks for the info. I will get them checked
