1 - 20 of 26 Posts
Registered 2012 SLK350
Have not been successful finding this in the book.
Can anyone tell me how to turn the radio off while using the GPS without turning off the entire unit?
was not possible on my r171 09
Premium Member 2012 SLK350
Can't do on R172 either (that I'm aware of).
then u don't hear the turn by turn directions, no?
Go to Audio, change to a media that's empty (like Sd card), that way navi will be on, but no audio is active.
that works? mine usually says no sd card present.
For the R171:
If you just want the radio or music to fade out or go quiet when the Navigation lady talks, then you can go into the Navigation system menu and choose Maximum Fade Out.
Press Nav. Within the Navigation Screen, press Setting > Nav. Vol > choose Maximum Fade Out (by using the up and down on the cursor so that the radio button next to the Maximum Fade Out is highlighted or filled in). Press OK.
If you just want the music/audio to be off, while the COMAND screen shows the map and the music is sounding its thing, press MUTE button just below the COMAND screen. Music will be off and the Sat Nag Lady will still tell you the verbal instructions.
Maybe the function is similar in the R172 with COMAND Nav.
Sadly Woolly has passed away
. . . and if you want the SatNag Fraulein to be louder, just turn the volume up when she's ordering you where to go (or, if she's keeping quiet, just hit the little speaker button, and she will repeat her last utterance, then turn the volume up ).
can't find that setting eddy on my 09 2.5 comand. it does state to turn volume knob to make the nav voice louder than the radio.
i hit nav and then there is no 'setting' choice. no biggie. thanks
Is it in the main system menu? Or it may be in the soft key menu within navigation?
not in the main menu or any soft key. not too worried about it, just wanted to mention it. is it comand 2.5 specific? do u have 2.5?
I have the NGT 2.0 (I know it's dated, but it works fine still :D)
so that is why it is different from my 2.5. no problem. ty
Select Navigation and destination.
Select media which is not currently loaded eg SD card.
The audio portion of navi is still audible, but no music or radio is playing because I chose a "device" which doesn't have anything loaded.
Reactions: jbanks15
Reactions: jbanks15
aka John
Jeff - on the 2.5, you should have the options to fade, mute, etc. - want to say it was included in the 01/11 telematics update. I'll go poke in the '55 tomorrow - it's a bit late tonight! :)
1 - 20 of 26 Posts
