1 - 8 of 8 Posts
Premium Member 2008 SLK350
Guys, I'm trying to do some variant coding but keep getting the Communication error 8.561.6067. bit searching has it's as a lock, but I can't find it in the actuations.
Anyone know where to unlock in ME97?, the desire to join the dark side is strong.:devilish:
Install anydesk and give me your ID on PM, i will take a look.
Need internet and the Sd c4 connected to the car
Thanks, but the time different with be a bugger, might try for really early Saturday morning, when's good for you?
a few hours in advance makes it trickier, I am 11 hours ahead of you.
I was going to try you little trick, with peddle curve change,
Researching found the SAM actuations has control unit lock, which locks the ECU. Might get another crack at it when I get home.
FYI, 8 pm in Australia is 9 a.m. the next day in the UK
My work days start at 5:30 am after a 40min drive, I'm good with US guys as I work with a US team, but never get to meet my UK colleagues
Apologies, stuck at work. Bit of snooping around with the oscilloscope, showed strange patterns, but nothing to compare with. So ordered another multiplexer from different vendor. I have read the multiplexer(Knock Off) vary. but luck this time.
1 - 8 of 8 Posts
