Hi tried a couple of code readers but they didnt work on my1999 2.3 slk
I first had to buy a 38 pin to 16 pin converter to use its new standed pin conector
the cars 38 pin socket is in the engine bay main wiring box passenger side in front of windsreen finally found a code reader that worked called the D900 went through all its function 2 messages Mil off and no fault code-64 crank shaft sensor
I dont know if this is good or bad?
a code reader that relies on cars battery input alone will not work
the D900 has 3 Aa bateries
Paul [happydad]
Paul [happydad]
