MOST IMPORTANT!!
THE TRUNK PARTITION HAS TO BE CLOSED
you have to hold the lock or unlock button while aiming the keyfob at the door handle/sensor no more than a few feet away. The closer the better. Any movement away from aiming it or not holding the button continuously will interrupt the procedure.
another reason to get the the SmartTop which uses rf and not ir energy
once, twice and 3 times is if you have the SmartTop and it is enabled. no holding. if enabled, 1, 2, 3 one second apart, no holding.
