I have a 2003 200 manual 140,000 miles its the best car I have ever owned but its electronically challenged
The latest episode involves the abs/esp/bas lights becoming lit after moving off with a clunking noise from the rear when the lights come on the noise goes at around 20 mph its fine till the ignition s turned off and a restart made has anyone else had this problem I have cleaned the rings & checked and cleaned the sensors and replaced the brake switch
You can stop the noise a slow speed by gentle pressure on the brake pedal any comments please
Paul
