Cigarette lighter needs to stay always on
2789 Views 7 Replies 5 Participants Last post by  curro101
Hi.
I tried to search this solution to my problem but didn't find similar question on this forum. So is there a way to have cigarette lighter always on?
Some MBs have option to change lighter behaviour by changing fuse locations so that lighters are always on, instead of turning off when ignition turns off. But R171 doesn't seem to have this option when looking fuse locations.
1 - 8 of 8 Posts
First please update your location and vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
See less See more
You can change the 12v positive feed to one from the end of the dash fuse box with an "add a fuse" easy enough, they're all 12v permanents there....
If I were to make that change what Amp rating would you suggest as that would seem to be a reasonable load? :O)
10Amp?
The original fuse for the lighter is 15A, so 10-15A should be fine..
Thanks for the info.
I tried to look "add-a-fuse" adapter, but can you please elaborate how it should be connected?
It's a piggy back device for getting another power feed from a fuse slot without loosing the original circuit
http://www.amazon.co.uk/Add-A-Circuit-Fuse-Holder-Standard-20amp/dp/1550063146
Very handy little bit of kit
Reactions: 1
You just pull a fuse from your fuse box and place it in the lower of the two slots on the piggyback fuse, you then put a fuse of the rating youdesir in the top slot and place the piggyback fuse in the original fuse slot on the car.
1 - 8 of 8 Posts
