Well I have a 2003 SLK32 AMG and I have a Check Engine light... Pulled the code it said secondary induction system? Anyone have a Idea before I send it to the dealer?
It might be a Bad MAF or sensor, When is the last time you had the airfilter filters replaced or re-oiled if they were aftermarket one's ?
Just bought it they had it at the dealer and said everthing was changed oil, oil filter, cabin filter, air filter.
D
Guest
To be honest mate i'm not 100% on it myself because the emissions systems are different in the US but as far as i know its a design fault that causes the secondary air pump relay to fail.
I will see if i can dig anything else out.
Sweet that would be great I dont want to be Tossed the run around with this when I take it into the dealer.
