1 - 15 of 15 Posts
Registered 2001 SLK320
Nice day yesterday, mid-60's, SLK humming fine. Stopped at last stop light before entrance ramp. Light changes, and of course, I'm behind the slowest person in the world leaving the line. After waiting for the other lanes to clear, I hammer down, get around the moving speed bump, running up to about 90 getting onto the on-ramp and motivating down the highway for maybe 30 seconds, before dropping back down to 70.
At which point the CHECK ENGINE light comes on. It feels relatively okay, and I exit in about 5 miles. At the light, I can tell something is not right. She is idling rough and poor throttle response, almost like she's not getting fuel or a coil pack is dropping out. I limp home a mile away at 30+ MPH and park and shut her down. Under the hood, nothing glaring other than a bit low on oil (she'd due for a change).
I start her back up and she's back purring like before. I run up the street and back, still good. Drive out to dinner and show later, again, good to go.
Only problem now is - stupid light is still on.
A) Any ideas as to what might have happened?
B) How can I turn the light off?
C) I have flexible maintenance, how can I reset the clock for the oil change?
New members and guests should be aware that the 'New Posts' link next to the 'Search' link top right of the info bar is a great way to see all of the posts you have missed since you were on the forum last. Remember to click 'mark forums read' under quick links when you leave.
Thank you,
Moderator/Founding Member
intro
Odd - I joined, as you can see, over 2 years ago, having brought over some information I had that I had previously posted on the BENZWORLD forum.
I do see now that my vehicle is not public, so I made that change.
I'm not sure why it does not show my previous posts as it contained the information for both the jack-point "pucks" and the rubber bumper in the trunk that supported the roof when stowed.
At any rate, my appologies if I offended anyone.
info in garage does not communicate with the info in your profile on left side. sent you pm
Premium Member 2013 SLK250
You need to have the codes read and that will tell you what is the problem. You do not show where you live. If in the US you can go to the big auto parts chains and most will do a reading for you. The codes will tell you what was/is the problem. You might want to reset the codes and see if it comes back. Could be a rare thing that happen and not a problem.
Thanks. Jeff explained the issue with the locale and car - fixed!
I'll stop by the zone or other chain and have them pull it. Do they all have the adapter for the Benz or should I call first?
Resetting service indicator and resetting clock info are both in your owners manual and probably on the forum somewhere via a search. Both pretty easy to do.
AutoZone pulled the codes and reset the light.
Appears the #4 cylinder dropped out when I was doing my high-speed run. It also said something like it needed a tune up. With 147K miles, it probably has the same plugs and wires. The coil pack on #4 may have dropped out.
So now you have your game plan!
They cleared the codes. Time will tell if you have a problem or it was a glich. Sometimes there is a glich and the cars computer will register it and turn on the check engine light and does not happen again. If comes on again very soon than you have a problem that needs repair work. You read the codes again and it is again #4 cylinder dropped then look at the items you mentioned. You could swap the coil pack with another cylinder and see you get a reading that the swapped cylinder was dropped. If so then it is the coil pack if it is still #4 then time for wires and plugs. I hope it was just a glich.
The codes to reset/clear are the ones for the check engine light turned on by the cars computer. You use a ODB2 reader to do this.
I ordered plugs and wires since they are over 11 years old with 147K on them.
The code they printed out: P0304 Number 4 misfire detected
This would explain the rough running and idle when I exited. However, from my way of thinking, plugs and wires should not magically start working again after a shutdown. I am more inclined to think it is something more electrically controlled. Unfortunately, the coil pack is not that "technical", it should fire when it gets a signal from the ingnition system/control module - which leads me to be wary of the ECM or ignition module.
We'll get the plugs and wires in and then we'll "wait and see". Since I will probably move the coil pack rail out of the way when doing it, I may follow the advice and swap the #4 coil pack with another on that side just to see if it is a weak link.
It is more likely to be a coil pack than plugs/wires. Coil packs don't stand up to heat very well over time and will develop small fatigue cracks. They will often start to fail intermittently at first and get worse over time.
Although the coil packs are fairly well shrouded on the 320, never hose your engine down when it's hot. Hitting a hot coil pack with cold water will eventually cause it to develop thermal cracks, suck in water and short the coil.
Swapping coil packs with another cylinder (as someone suggested) is a good idea at determining if it's the coil, plug, wiring, etc. On modern engines they don't use plug wires anymore. The coil packs plug directly onto the spark plugs and a low voltage signal is used to fire it so there are no longer any high voltage wires that can break down like on older engines.
Hope this helps,
Rob
Hi there, my check engine light came on also this morning when i push the throttle hard, then immediately i park the car and check. It seem no problem with engine, it response as normal, what i'm worried is the check engine light, i drove 55miles and it's not turning off, i will check later after work if the light still there. my car was R170 SLK230 2002 from US shift here in United Arab Emirates and now it's 66
Degrees Fahrenheit here. Do you think what cause this light to turn on this is the first time. Thank you in advanced.
You are fine to drive the car with the CEL on. It only has to do with emissions related faults. You will need to read the fault code with an OBDII reader and report back. There may be more than one. Most auto parts stores will pull the codes for you for free if you don't have access to one.
Rob
1 - 15 of 15 Posts
