I have just finisher changing out the plugs on my R170. Prior to doing it I had read a lot about how hard it can be and how you need a special 5/8" universal plug wrench. Well I happened to have one but found the job easy to do without it, in fact I did try it but didn’t needed it, at all.
This is what I used
Torque wrench 3/8” drive
3/8” * 8” ratchet
3/8” *3” extension
5/8” plug wrench * 1/2" Dive
5/8" plug wrench * 3/8" Drive (Used on the two back Plugs ONLY
1/2”*3/8 adaptor
T30 Torz Wrench
And I made the wrench to get the plug boots off and on.
It also took just under 2 hours to complete the job using the above tools. Hope this will help others out when thinking of doing this job.
Pictures of took below
:tu:
Not sure what the 5/8 universal plug wrench is, but I used the same tool you did except I had the MB Boot Puller. I agree, they worked well. Thanks for posting the photo of tools used. I would have loved to have seen this photo as a guide of what is needed before I started.
It probably would have saved a few dozen trips back and forth to get the right tools :tu:
Yes, I know what you are talking about. I actually had one of those in my tool kit, I tried to use that and it made it much more difficult than using the traditional one. Could not feel what I was doing and could not get the right angle to tighten or loosen the plugs.
