I have an intermittent bulb fault with my drivers side headlamp. On looking I found the holder was loose in the headlamp. I took it out to have a look reseated the bulb in the holder. I read in my owners manual that the holder needs to click into place. What way up should it be? Should the flat shoulders be horizontal or vertical when in the headlamp?
until someone replies, look at the other side?
I need to check on that... There's only one way you can screw it in. Once it's in it will find it's thread and you should be able to twist it clockwise and feel it stop after 1/4 of a turn I would say... But let me double check on that!
Here's how mine looks like. Please note that it's a US version and I have projector headlights.
Thanks guys, My headlamp is standard halogen. I had already checked the otherside and its vertical, but there appear to be cut outs on the vertical for the holder to slot into. My manual just states push it till it clicks. After *****footing around trying not to damage the holder I resorted to good ole brute force and it finally clicked into place.
I think at some point the bulbs have been changed and the wires on the holder have been pulled to get the bulb out, hence the intermittant cutting out.
