Registered 1997 SLK 230
I've found a Carsoft 7.4 Multiplexer for sale on t'internet for just 30 quid - so, not expecting too much info from it, I thought it might be worth a go.
Mine is a 1997 SLK 230 with only the 38 pin OBD connector, and reading elsewhere I think this multiplexer might allow me to see error codes on a laptop, if nothing much else.
However... the multiplexer output is to an RS232 serial cable, and none of my laptops have such a socket.
I was wondering if anyone is successfully using this device with one of the RS232-to-USB converters that are cheaply available on eBay
and also if anyone can advise whether it's worth having this device?
TIA
Sadly Woolly has passed away
I use serial -> USB converters on a variety of different instruments, and have never had a problem connecting anything up yet. Just make sure you configure it to select an unused USB port.
There are quite a few posts on here about people using even cheaper (£10-15 ) OBD scanners that link to a mobile by BT, and they seem to work quite well.
Hmmm... I've just had an email back from the multiplexor vendor to say it will NOT work with a RS232-USB connector. As it's losing him a sale I guess I've got to go with his advise really!
so... you mention these other scanners, but I can't find reference to them, could you be more specific about which would work for me, I'd be very grateful.
Paul
Registered 2009 SLK200
I bought one of those years ago never had any luck with it but was using it to convert to usb port .
Save your money and get something decent that can actually go in to the older mercs and actually pull codes off .
The cheap code readers are very basic .
It all depends how far you want to go in to the sytem etc . :tu:
