I recently has a oil leak from the camshaft magnet cover on my 2002 slk,which is now sealed with the aid of silicon,which also has a stopper fitted on the wiring loom,what i want to know is should there be oil in the end of the cam with it being electrics?
Premium Member 2002 SLK230K
The leaking camshaft magnet is common with these cars. I had to replace mine a couple of years ago, its a cheap part from the dealer and takes 10 min. to install. When you remove the old one clean the surface (engine side) good, put a small amount of high temp silicon on the surface and install your part. Your plug connection if i remember is at the 10 Oclock position to prevent oil from leaking into the wire loom, have a look for signs of oil in the plug anyway.
