1 - 17 of 17 Posts
Premium Member 2004 SLK200K
I did all mine by hand , with bubble free carbon fibre sheets for less tha £10 , but you have to take eveything apart !
his link is to the aluminum brush and not the carbon fibre
Same work , different material ! Sheets of bubble free brushed aluminium are also available !
By the way , what pieces are included in the kit ? I can't see any parts list or diagram or photos ! Or is it because I'm on the ipad ?
I have cf also but the ones from slkstore. I'm lazy
Thank you guys.
Curro, you did an amazing job. But I am not up for the task of taking everything apart and potentially ending up with parts not fitting back well. I am hoping that someone will reply with any ready-to-install options. Thank you,
Me too (like most men) , but I'm more poorer than I am lazy !!!
And then there's allways the satisfaction of doing it yourself , as long as it comes out right and doesn't look like a five year old did it ....
Thank you guys.
Cheers !
I think JonB bought a set from these guys and was happy with the quality !
http://www.ebay.co.uk/itm/MERCEDES-SLK-R170-R171-170-171-INTERIOR-DASH-TRIM-KIT-/261081469683?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cc9ab12f3
By the way, my SLK 350 already has the brushed aluminum trim. But my main reason for trying to get a kit is to cover the radio/navigation system area and the middle consol that are showing scratches. But it looks like I will have to purchase the entire kits anyways with sections I do not need.
Curro, how much trouble was the handbrake?
Not much at all really , just a bit not getting creases on the tight curves ! Believe it or not the hardest part was the AC controls , removing the internal lighting system -one piece for all four dials !
Anyone else think that it's really daft Mercedes not selling the handbrake cover seperately , how daft is that ???
i know. you have to buy the whole handbrake assembly. idiots!
cutting out for buttons
hi, how did you manage to cut around the small buttons on the comand. did you take the comand apart/remove the fascia ? thanks woozzle
Yes I totally dissasembled everything ( not as hard as it seems ) and cut out the wholes with a cutter / stanley knife / scalpel , the only part you can't remove is the clear display , but it has a slight recess , perfect for cutting round !
I purchased a decent brushed aluminum (real metal) ket but I saw another kit that says their pieces have rounded over edges. Mine are die cut and you can see the underlying material. This other kit would appear to have a better finished appearance. I do not recall their website address but I think it would be worth searching for unless you want to take everything apart.
1 - 17 of 17 Posts
